clutch problems help!
95ranger2.3l
hey,
so my clutch on my ranger is acting up, its sometimes not fully disengaging so its not going into gear, start from a stop obviously. if i pump the pedal a few times then it goes into gear and then it will be fine?then sometimes coming to a stop,i put it in gear then when i take off i start to disengage the clutch, and theres a big rattle/grinding then when the clutch grabs in goes away?
what i've done so far is replace the clutch master, and bled it twice after.
im thinking there still is a air bubble in the system
plase any help will be appriciated
thanks
is there any sign of fluid leaking out of the bell housing, you might have a bad slave.
The rattle is indicative of a mechanical failure of the clutch itself or the pilot bearing. Time to pull the transmission and take a look at everything.
there is a little fluid out of the bell housing, im going to replace the slave.
If theres enough miles, you may want to consider replacing the clutch and everything else in the bellhousing.
