Anastasius
- Apr 6, 2010
Good day,
I have been lurking around these forums for years and have found a lot of great tech info whenever I have had a problem with my Ranger.
My latest issue is I had a clutch installed in August of last year and it seems to work great. Now what is happening is when I push the pedal to the floor it is not completely disengaging the clutch. I will still roll forward with the clutch pedal to the floor and I cannot shift into 1st from a stop at all. I have to rev match to go thru the gears while driving. I am assuming this is something to do with the master or slave cylinder on the clutch. Also the pedal seems to vary as in sometimes have very little pedal and others I seem to have more pedal. Can anyone give me some pointers on what may be causing this problem?
Thank you for your time.
