zboyd4837
- Aug 19, 2018
Soo this thing has me stumped and before i go pulling the trans out again, i thought id ask on here...so i have a 2000 model Ranger 2wd 2.5 5 speed...
The problems started when i had a by passing master cycle. So while i was into the whole master cycle deal. I decided that i might as well changed the clutch. So I have everything new... Master cycle, hoses, hose from the master cycle to the slave, new pressure plate, new slave and throw out bearing, piolet bearing and all new tranny fluid.. Any part that is involved is new..
OK this is what the trucks doing now... Ive bled all the air out of the system and have a very very good petal.. When i started the truck it had a bad squealing so I turned it back off and bled the clutch once more.. So i had the truck Jacked up in the rear with the truck in first gear clutch pushed in the wheels are spilling a light squealing... with the clutch still pushed in the wheels still spinning and i still cant change between the gears... i took the inspection plate off and had someone push the clutch in and its in gauging like it should or from the looks of it anyways...Can someone please help me???
