rangerboy1986
I just replaced the clutch and flywheel on a 1986 ford ranger. 2.3L, 4WD, 5 speed trans. We got the clutch, pressure plate, flywheel, etc.. installed correctly. The truck starts up, and goes into gear smooth. Actually it goes into gear easier than before. No grinding or clunking. We bled it like you would brakes. However when you start the truck and put it in gear the pedal comes all the way out before grabbing hold. Literally right before you take your foot off the pedal that's when it takes hold. The pedal is super soft, and when it finally engages it doesn't engage enough to move the truck. It wont move a foot on a flat surface on its own. I think there is still air trapped in the system but when we bleed it we don't see any air coming out. I read to bleed the clutch master cylinder, i read to let it gravity bleed, i read to backwards bleed it. Does anyone have any other tips or possible solutions? I'm about to head to the shop and work on the truck some more so please reply as soon as possible. Thanks people.
