92SHOinPA
97 Ranger, 90,000 miles. Trans fluid replaced every couple of years, most recently a few months ago. Always use Mobil1 atf. Still running original clutch.
This truck is getting progressively harder to shift. Getting into first gear is a real challenge, no grinding, but very hard to engage. 2nd thru 5th are also difficult to shift into while sitting still, but work fine while moving. Very recently developed, reverse can not be engaged (without grinding) unless you shut off the engine first. All gears engage smooth as butter when the engine is off.
I am assuming that this all points to a clutch replacement, correct? Or is it syncros and blocker rings?
If it is the clutch, what should I do about the TOB / slave cylinder. Of course I would replace the TOB & pilot brg. What about the slave cyl? Should it necessarily be replaced too?
And I see listings for 6-bolt and 8-bolt flywheels. How can I determine which I have? I want to have all my parts ready to go before I start the tear down.
TIA,
Bob
97 Ranger 4x4
95 SHO 100% stock
92 SHO w/ a mod or two (see my web site)
Bob's Web Site
TIA,
Bob
97 Ranger 4x4
95 SHO 100% stock
Bob's Web Site
