Joey Stacks
Ok this is a thread in response to my "cold weather warm up questions" thread where people stopped checking it. I have a 92 ford ranger 2.3 4cyl Manual trans. The Clutch pedal has a habit of having too much travel in the mornings when its cold and there is a leak somewhere and im thinking about replacing the master cylinder in hopes that it fixes the problem. Every couple of days i have been adding fluid to the reservoir to keep the clutch managable. Even if the fluid is pretty high it seems like it wont work until i top off the fluid. So im going to put a new master cylinder in.
The main questions are... Do you think this will fix my clutch problem
Should I change any of the other parts too?
What type of tool will I need to do this job. in the manual it says I need a special tool for the quick disconnect fittings but dosent say anything more than that so if you know the tool its talking about that would be helpful
Also if anybody got pictures or suggestions to help me out they would be appreciated Im pretty new to working on vehicles and I want to be able to do things myself to save money and learn experience
