Clutch M/C
reno
I am going to learn this Hydraulic clutch System yet, I'm not having a problem, just wanting to know. How do we bleed the M\C Clutch? I know on the brake M/C you place the 2 hoses from where the lines connect and place them into their respected resovoirs and slowly pump until it is bled, but what about the clutch M/C? How do we gt the air out of it?
the 93' and up MC's usually have to be bench bled. Remove it from the vehicle, have a helper hold the resivoir up. Roll the m/c around to help air out and push the pushrod in. It should feel like pushing on a steel block, since liquid cannot be compressed and air can. Then reinstall, and bleed, be let in gravity bleed first. Then close the bleeder, open the bleeder and have the helper press the pedal. Close the bleeder, and let off the pedal. Pump the pedal slowly 5 times, then the last time let the pedal flip up quickly. press pedal, and let air bubbles out. Close and let pedal . Repeat till you have a good pedal feel. During this whole time, never let the resevoir go dry, or you'll have to start all over again. :D
