Clutch Line Replacement
Harry III
I need some tips on replacing the clutch line on a 1997 Ranger 5.0.
The original truck had a 2.3 engine manual trans.
I am going to replace the master cylinder and the line.
I know how to disconnect the slave cyl.
Any tips on replacing the line would be appreciated.
bench bleed the line prior to install. This will save you a hell of a lot of time. Also, when comes time to clip onto the master cylinder, do not be scared to push her hard, when new there a bitch to clip in
Thank you. A
Any tips on routing and attaching the actual line?
