Clutch interlock switch
91blueoval
So I see the little white retainer clip on the clutch interlock switch in place, however the switch is a little wobbly where it meets the master cylinder fitting. Is it supposed to be like that?
That's normal, as far as I've seen.
If your lookin to disconnect it, I used a ball point pen and 2 zip-ties.
Pop it off the clutch linkage, and take apart the pen,
Cut the pen tube to the length that fits in the switch and depresses the switch,
Put one tie around the switch and the other holds it under the dash.
Mine popped off one day without me knowing while pumping my clutch at a stoplight, bad slave cyl. Due to the slave I then stalled it. I came up with that in the middle of an intersection in about 2 min. I got er runnin.
