Clutch hydraulic Line Routing
belovedb2
I have found a clutch hydraulic line for my engine/trans swap. It has the correct fittings on each end but I am not sure of the routing. The line has a right angle on the master cylinder which would direct the line downward. However, it appears to hit the frame.
Could someone with a ranger with a 4.0L engine and manual trans look at the routing and describe it to me. Pop the hood and view the clutch master cylinder. Then describe the routing of the hydraulic line as it is connected to the side of the trans. Thanks.
