belovedb2
- Jun 17, 2009
As you all suggested I am replacing my B2 trans (FM145) with the stronger M50D trans as part of my 4.0L swap. I am at the stage where I need to find the correct hydraulic line from the M50D trans which has the quick connect and on the other end to my master cylinder which is held in using a pin. The B2 is a 1986 and the M50D is from a 1998 explorer. Do I order the 1998 clutch line or is there some other ranger part from the M50D trans that would be the correct part?
