TrexMex
- Sep 30, 2007
- Age
- 48
So I've just put in a new clutch press, disc, and slave cylinder (carrier bearing included).. Started bleeding the clutch to find out that the pedal was going in without any effort, even though no air was going out of the system. With the engine running, it seems like the transmission is always in neutral, I can easily switch gears without even stepping on the clutch. When looking through the inspection hole in the tranny it doesn't seem like anything moves when depressing the pedal....
I called it a day today and plan to see if I can fix this tomorrow, but would like to know if there is anything I should be looking for.... any help would be greatly appreciated!!!
