LilBlueTruck
- Feb 24, 2008
Hi everyone - I am going to attempt a clutch change on my 2000 Ranger 4x2 4-cylinder this week and I am looking for a few tips. More specifically:
1. With the quick-disconnect hydro clutch line, am I correct in saying that the line will NOT need to be bled after reassembly?
2. Is there anything that needs to be readjusted in the clutch assembly before putting everything back together, or is a straightforward take-one-off and replace-with-new procedure? I have some instructions from AllData that say something about an "adjusting-ring" on the clutch pressure plate.
3. Does the quick-disconnect tool slip between the plastic-grommet and metal piece that sticks out of the tranny casing?
I will be putting on an all-new CenterForce clutch (disc and PP) as well as a new T/O bearing. I have never done this before on a Ranger, but I did a clutch change on my FWD car when I pulled the engine out for an engine-swap, so I do have a reasonable level of mechanical experience. I have a few shop manuals (Haynes and AllData), but as most of you know, these things are only so good. I am just looking for any tricks that might be specific to the Ranger that can make this go a bit more smoothly. Thanks in advance for any input that you may provide.
