Lovetherange
So I took a instrument cluster from. 93 6 cylinder ranger and stuck it into my 94 2.3l 4 cylinder for the tach considering mine did not come with one... through research I have found that it is rarely plug and play... well I have gotten a response from the tach needle(not sure how accurate, please let me know if I can adjust this) the speedometer seems to be a little further off so I may swap the speedo needle from the 94 cluster for better accuracy... the problem I have is this, my gas gauge now doesn’t work... when I turn on the vehicle it goes past full and works down to below empty and stays there... the other cluster the gas gauge half worked... ergo it would work at a quarter, half and full... any advice? Thanks a million in advance.
