"Clunking" into reverse
gregorys1989
Ive tryed this thread before and didnt get much so ill try again. My 92 ranger is 2wd to start. When the truck is in park and at an iddle i get some shaking. not to much butt a little. when shifting into reverse from park there is a short pause and then it makes a clunk noise before switching into reverse. Ive heard a couple suggestions as to what this may be but im hoping someone on here can clear this up for me.
Ive been told.
-U joints
-Drivetrain fluid
-motor mounts
have you ever done u joints?......i had the same thing and u joints was my fix......
does it ever clunk into drive?
It does barely. Not even really noticeable, well at least compared to shifting it into reverse. No i have not done u joints , butt i heard it is not that hard of a job.
It's a A4LD. They do that. Ignore it.
Both of my rangers clunked into reverse and clunked a little into first, and always clunk when in OD because of the toque converter lock up.
u joints took me about an hour to do all 4 and most of that was beating the old ones out....
get under the truck and see if their is any slop in the driveshaft
