86RangerMan
- Jun 18, 2008
Hello, i have a question.. when i start my truck up, starts fine, but, when i go to push the gas pedal, i hear clicking coming from the computer.. is this normal.. also while i'm driving, i hear ckicking... sometimes it stops, and then starts again... i found a ground strap disconnected, from the frame to ??? at around the battery box ( strap was flat about 2ft. long ) so i removed it, and ran a ground from the header bolt to the frame.. thought that that may be the problem, not...... still clicking when driving, and also clicks when sitting still, as i push the gas pedal... is there more grounds that i need to look at?. if so, where are they located... 1986 ranger 2.3 efi 5 speed trans... thanks..
