- Aug 6, 2007
- Age
- 37
- Plattsburgh, NY
1999
clicking in the front end???? an a check engine light question?
hey guys ive noticed if i go over anything other than a paved rd i have some clicking going on in the front end.... its getting REALLY annoying.. i took a quick peak an coudnt find anything outta the ordinary.. my buddie suggested it might be an abs sensor thats really close?? its a 95 4x4 4.0 it has warn manual hubs so i know it cant be the crappy auto hubs..lol
Check engine light problem.. 2 nights ago i was driving home from work an the light came on.. well i pop the hood an had a listen an it sounded like a vacuum leak an it was.. the lil red line that goes from the grommet on the intake to the vacuum ball had broken at the grommet. no biggie i pull off the broken piece an push the line back into the hole.. i disconnected the battery for about 20 min light stayed off.. between then an now ive done 45 miles an the light came back on.. i went back to autozone an had them plug it in an it had the same code excessive erg air flow.. p1041 or something along that line.. i was telling the guy i had it plugged in 2 days ago for the check engine light an the guys like you cant disconnect your battery to get rid of the light you have to erase the code with the scanner tool.. so he erased the code with the tool... so far its been alright but ive only done like 13 miles.. does this sound right to every one ?? you cant disconnect your battery to get rid of the code?
