cleaning my injectors help
jimbean
i was reading on internet that i could clean my injectors by soaking them in carb cleaner then the guy wrote that while cleaning them you could put power to them for a second and it would open the injector and clean the insides
anybody know if a 2.3 ranger 1993 injectors will take a ground and a positive
to open injector {the whole 12 volts ???}
do what i did. 1- fill fuel tank. 2- get 2 container of Lucas fuel treatment. 3- go for a 3 to 4 hour non-stop cruise. and then you will have your pep and performance out of your clean fuel system at a low cost
I have read about a product called seafoam , I guess you add it to the fuel and it smokes like a banshee but cleans very well . no idea on cost or application , just read about it
Seafoam does work wonders with cleaning your motor, you can find it at O'Reillys or Autozone.
Did it on mine with a circuit box worked good.
14V 1.3 Amps
You can set up a switch or just be the switch at the box removing the wire clip.
I stuck mine in an ultrasonic cleaner full of MAF cleaner and left them open (circuit on) for a minute at a time. That cleaned em out real good, got a paint flake like chunk of carbon out of a few of them. Be sure to retrieve the filters out per the instructions from the earlier post with link, those are the most important part I think, most of the stuff doesn't get passed that.
Good luck
X2 on the Techron and Seafoam both work wonders!
