hotrod101786
- Jan 29, 2010
I just changed my timing belt last night. before i took the old one off i marked on the cam sprocket across onto the timing belt and then made a different mark on the crank sprocket onto the timing belt. then once i got the old one off i layed it over the new one and made the two marks on it. All my pulleys were aligned with the right symbols but as i was putting the belt on the pulleys moved a little and i ended up having to turn them back around to their top dead center symbols. i made sure they were lined up and that my two marking lined up with the marking i made on the cam and crank. Then i manually turned the engine over a few times to listen for valve and piston contact and heard nothing. so i started the engine and it immediately was making a clattering noise so after about 4 seconds i shut it off. I left the truck at my works shop and when i got home i started web browsing. i read that these 2.5's are non interference engines so they wont bend valves. so if thats true then what could the clattering be? i also read on another site that sometimes the lifters will tap for a bit since rotating the assembly lets oil out of the heads and i should let it run for a few minutes.
