akatagyourit
Good evening everyone,
So couple of days ago my truck overheated and blew the head gasket. Upon getting it home via tow truck and tear down the water pump had no fins (previous owner ran straight water which rusted it out, welcome to florida). I ran a compression test also just to see how it stood.
May 2016 comp test 160, 180, 180, 170
December blown gasket 60, 60, 115, 170
Since rebuild - 180, 90, 180, 170
Now as you can see it had good compression when I got it in May of this year. Blown gasket plus cracked head = horrible compression.
I bought a brand new head assembled and put it in. Got everything buttoned up and ran a compression test just to verify before going to far. Everything was great except cylinder 2. Thinking it might be rings I put some oil in the cylinder and ran the test again, only increased to 100 psi. Don't think its the rings. So this leads me back to the head. I got everything set so I could fire the truck up just to see what it sounded like. I thought it was a rod knocking from in the cab and was pissed. When my neighbor got home I had him fire the truck and listened and it sounds like theres a clattering in the valve train. . I've gotten the valve cover off again and looked everything over, but cylinder heads are greek to me. I dunno what to look at/ touch / mess with to find the issue. I know its cylinder 2 though. I also know that on the valve cover is the vacuum port for the pcv system and it was absolutely pressurized when the truck was running, leading more towards a valve leaking. I'd like to try and fix the issue without removing the head again, already spent more than I wanted to on this. Since its hydraulic theres nothing that needs adjusting so should it just be the hydraulic lifter thats and issue or what? What can I do to find the problem and fix it. I seriously don't want to tear it back out and replace the gasket and headbolts again.
