cig lighter?
407Link
Orlando
My truck has to power outlets and the one on the driver side doesn't work..can't seem to find the fuse for it
i don't have it and can't find one on the net
i found the fuse that says cig lighter and it doesn't go to either one...i had something pluged in the one that works and removed the fuse and it stays on and the fuse is good The power outlet one works but the cig lighter one does not. i tested every fuse and they are all good? about to get behind it and look..thanks for the help
my cigar lighter and horn are on the same fuse on my 88. might be the same or it might not.
thanks it ended up just haven alot of stuff in it from using it for a lighter blew it out with an air hose and now it works for my cb
