Chrwilkins30's build
I did pull it. Just didn't think to get the year. I was kind of in a rush went between classes.
Might just have to go back and look at the year
it should have a vin on it try running it through the vin decoder thats on here, should tell you what you want
Also. Any one know if they make replacement brake dust shields?
I searched real quick and someone said that only 90-92 d35 came with dust shields. Any truth to this?
Quick question. Those shocks I got are not forcing the shaft out. The thing is the new shocks didn't even have the metal string holding them in the compressed position. Do you think I should send them back. Every new shock ive bought had that metal wire but not these.??
They are a hydraulic shock not a gas charged shock. That is why they don't extend on their own.
Sent from my PC36100 using Tapatalk
Just got your pm. Tapatalk doesn't notify me of messages.
G2 Gear Ford 8.8-Inch Master Install Kit Part# G2 35-2013 86.95
G2 Gear 4.56 Gears For Ford 8.8-Inch Axle Part# G/22-2013-456
G2 Gear 4.56 Gears For Dana 35 P/N G/22-2065-456R
G2 Dana 35 Reverse Major Install Kit P/N G2 35-2065
That seems like everything?
Seems like it is everything you need.
Ordered the gears from Jim, Escorts installing the gears, and getting 8.8 on thursday.
Good week for the B2!
Got the rear axle today. 8.8 with disc from a 99 explorer, 3.73 open.
Started tearing down the d35 and cannot get the pinch bolt off. Its the recessed ones, Found out its from a 91. Any know the size of that bolt.?
16mm. Or was it a 17mm?
Are you talking about the bolt on the driver side of the diff?
