NicoNO82
- Jan 16, 2009
- Automatic
I realize this has probably been asked a million times before but I need some suggestions.
Goals:
remove speed limiter
change/adjust shift points
remap fuel and ignition
calibrate for different ring and pinion gearing and wheel/tiresize
Also seems like there are not too many options to get rid of the damn restrictive MAF section in 4.0L intake tubes? The aftermarket MAFs like the one offered by Jet are for older models with a differnt wiring harness and an external air temp sensor. Any other options? rigged F150 MAF? harness is the same but intake tube is larger. or just use stock in a bigger tube and use a chip or piggyback thing to recalibrate?
Goals:
