Checking brake wear, found broken blocks!
01 4.0
SoCal
New buy for my son. While checking rear brakes today we found 1"cast iron lift blocks under leaf springs on both sides were broken. Unbolted the u bolts pulled the blocks, tossed em in the trash and tightened up the u bolts. Is this a common issue? Are cast blocks OEM?(we will be cycling the suspension to make sure shocks are not bottoming)
They break. Cast not so common for fails but aluminum suck.
They were probably factory, but we need a lot more info to be sure.
Yeah I went to hd 1 ton blocks from the ranger stuff.
Ranger stuff rots and breaks easier.
The Ranger OEM blocks have hollow cavities on the one side. So I can see them collecting dirt and road salt in there and rusting from the inside out.
