jewalker7842
I have been doing research on this problem for weeks and I think I have come to conclusion that it is my check valve in the tank.
In the mornings I have to prime the pump about 5 times to get to the truck to start right up. I can turn the key just once, but it takes about 5 seconds to start up, and I don't want to wear out the starter. It will start right up if I don't let it sit for more than an hour.
I have done a recent tuneup on it. Plugs, plug wires, air filter, pcv valve, fuel filter, cleaned MAF and IAC valve. I have no CEL light on. I am getting an average of 17mpg mixed with city and highway driving with traffic.
I have not done a fuel pressure test yet. I do not know anybody that has a fuel pressure gauage that I can use. I do not feel like spending $50 if that can be used towards the fuel pump that I would need to replace if the check valve is bad. I'm going to put some Redline SI Fuel Injector Cleaner cleaner through it and see if it does anything. It is worth a shot. Highly doubt it has any effect on a check valve though.
It is a 2001 Ranger XLT 3.0 2WD with ~115000 miles on it. Other than the start up problem it runs great. Are there any other things I could try before I buy another pump and dig into this thing?
