Hey all, I have been having a strange issue with the CEL after the rebuild. Before I pulled the engine I had no issues with the CEL. Now the light comes on after driving for 5 to 10 minutes. Turning the truck off then back on turns off the CEL. It turns off the light even if you cycle the key at a traffic light.
Can you check for codes after the light comes on and the engine is still running? Are there some codes that don't stick and go away when the key is turned off?
The truck is running great and there is no change after the light comes on.
Thanks
Thanks
