Just for future reference you should not replace sensors that report a problem, the fact they reported a probem usually means they are working.
I would clear the codes again and then start cold engine, engine will run rich until warmed up so you should get no CEL, and in any case the O2 sensors are not being used for the first few minutes to report the lean condition.
If you do get a CEL then yes, computer issue.
Time how long before CEL does come on, and where the dash board temp gauge is, or if you are monitoring live what the ECT temp says.
The MAF sensor data is used by the computer to set Gross fuel/air mix and the O2 sensors for fine tuning, but only the MAF is used when engine is cold.
The MAF works by air flowing passed it, so any air entering the intake that doesn't pass thru the MAF would cause a leaner mix.
So the air plenum(tube) between MAF and intake must be air tight, any leaks here is the same as a vacuum leak, it is called a ported vacuum leak but a leak none the less.
A lean condition could be the computer misreading MAF data or bad wiring to MAF or bad MAF
Could also be dirty injectors, run some Seafoam in the gas tank see if things improve.
Easy test for vacuum leak is to warm up engine and then let it idle, should be 750rpm.
Unplug the IAC Valve, idle should drop to approx 500rpm or engine might stall, thats a good sign of no vacuum leak
If idle doesn't drop or drop alot then you probably have a vacuum leak.
Start removing lines and plugging hole with your finger, see if you can find the leak.
Include power brake and PCV lines.
And a long shot would be the Flex Fuel sensor, quite a pricey item, like $750, this sensor is on the fuel line and tells the computer the ethanol content of the fuel, now I would think an error here would cause a rich condition(if using 100% gasoline) not lean, but..........
