Dusty_Ranger
Ok so i've been seeing alot of people lately asking how to get a few extra inches out of there stock suspension for cheap so i decided to put in my .02 cents and do a mini write up.....
well the tips im about to give you have been done by me and its all used or new if u want, go to the nearest auto wreckers and get a set of ford Explorer front coil springs (about 25$ each) and a set of rear leaf springs (50$) out of and explorer the year ranger is 1990-1994 go to the hardware store and get 2 leaf spring center bolts for the ranger leafs springs, then when u get all the spring start on the rear remove the rear wheels undo the u bolts on the axle (keep in mind u may also need new u bolts) using a grinder cut the center bolts on the ranger and explorer leaf spring packs, once thats done remove all leafs (except the main leaf thats bolted in) and rebuild the ranger spring using the individual explorer leafs u may choose to use a few ranger leafs (i did i ended up with a five leafs spring pack ) once the springs are how u want them slide the new center bolt in and tighten it up, reattach the axle and put the wheels back on, then put the explorer coils in the front and your done. the explorer springs all the way around should give u about 1.5-2.5" of lift and it should cost your wallet about 150$ cheap and proper if u have any question email me at dusty_ranger4x4@live.com
this write up was originally written by me for a guy on car domains who wanted to clear 32's when i did it on my truck i was able to clear 31's with no rubbing at all the guy mentioned reported that he gets very minor rubbing
