- Jan 5, 2003
- Age
- 38
- Bellingham, Wa
I figured it out!!! Idiot Savant!
I learned something form all of this. Too many people use Google to argue on the net. Surprisingly all the big words and references used in this thread are on the first two pages of a Google search on the topics being discussed.
I love the net. :lol:
I think the burden of proof is on you, sir. Show us the math!
...but in order to acheive a much more desirable outcome, it's best to do the math. That's why I tend to puch for certain mods, even though you can't hear, or feel some of the changes, the numbers cannot lie.
Hmmmmmmm! Gross calling someone else arrogant......pot calling kettle.....chickens coming home to roost.....et al.And isn't it the height of arrogance...........
I will get started on the math and post pics of the papers soon, (it takes a good minute to perform these equations, if you've ever done one, you'd understand)
This is thermal velocity broke down
In this graph, assume that x-temperature
When a moving particle (air/fuel) inside the temp. gradient, collides with a medium (heat, or spark if you will) it will reach an equilibrium distrobution.
Now if you do your math on this, you will see the possible velocity in whcih, your "flame front" (as someone previously refered to as) will travel inside the combustion chamber.
BUT, there is still a variant that must be considered, the initial amount of heat. Thats where the rest of boltzmann's equation comes into play.
Just to my luck, someone has already made a nice little program that will graph the outcome, when more initial energy (heat) is introduced into the equation. Here is the link.
http://www.chemsoc.org/exemplarchem/entries/pkirby/exemchem/boltzmann/boltzmann.html
I might believe your head isn't in your posterior.
And second, the equation begins by defining the random possibility of particle placement in a defined area, then goes through to give the probabliity of a rate of change during an alteration process of just about any kind.
On a more personal note, how can you assume that a human cannot perform an equation that was written by a human?
