ZacLoveall
- Jul 2, 2024
- Kansas City
- 2.3 (4 Cylinder)
1997 Reg Cab Ranger 2.4L 4CYL 2WD Manual Trans.
Battery Light on dash came on this morning. Went off shortly after. Has been "intermittent" since.
Light comes on mostly at High RPM. AC was on, tested with AC off as well. (AC also seams weak)
Took it to AutoZone, checked battery, alternator and starting system.
Their little machine said battery and alternator were GOOD, but starting system was bad?
At AutoZone, they "could not" check at high RPM.
Planning to check serpentine belt tension
Planning to check alternator output at high RPM this evening with Multi-meter?
Have a 200mile trip coming up, wanted to see if anyone had any suggestions for other things to check?
Any prep I can do before the trip, so I dont get stranded?
Thanks in Advance
Thanks in Advance
