This is on my '97 2.3 5spd.
A week or so ago, I was getting a CEL. When I had it read, I was told that my idle air control valve was bad. The following weekend, I pulled the upper intake(I finally got to do those last two plugs...) I cleaned the throttle body, MAF, air idler and upper intake. I also replace all of the gaskets. Put it all back together, and the CEL is gone.
However, since then I have had a charging issue. Everything will run great until I apply either my break or clutch, then my lights dim and I begin to lose power. Sometimes I lose enough to completely stall out.
I pulled the alternator. It tested fine. I pulled the battery from my '98 2.5 and put it in the '97, same issue. I am down to checking wires and connections with my multimeter.
I am curious if anyone has any thoughts on what else it could be. It seems odd to me that it just started when I cleaned and replaced gaskets....
Thanks,
Tyler
Thanks,
Tyler
