rangerman01
- Apr 30, 2009
vital info: 2001 2wd ranger with 4.0L V6, 5spd manual trans. with about 140k miles. according to the sticky the trans is a M5OD-R1HD.
I have been notincg a whining or roaring sound at a certain rpm (2000). I have isolated the sound to something in the drivetrain. It only makes the noise when the truck is in gear going down the road. The noise seems consistent in all 5 gears (haven't thought about it in reverse). Anyway, to try to solve this problem I want to change the tranny fluid. I know I can just top it off, but I would rather just start fresh. My question is how do I go about doing this? From what I have read the spec amount of fluid is 2.75 quarts. But I am not sure what fluid I need to put in the tranny, is it the mercon ATF fluid instead of gear oil? Also from what I have read here most of you guys poor the fluid in from the shifter instead of the fill hole on the side of the trans. How do you do that? I mean is it as simple as removing the shifter boot and pooring the oil in? I just don't understand where the poor the fluid into on the trans. Thanks for the help.
