adsm08
Senior Master Grease Monkey
⭐Supporting Member
Ford Technician
- Sep 20, 2009
- Dillsburg PA
- 4.0 V6
- Tire Size
- 31X10.50X15
It says I have a 7.5" 3.73 ration gearing, 28 spline axles.
Then you have a 7.5. The front of the 8.8 axle housing is deeper to accommodate the wider gear. It WILL NOT WORK with a 7.5 gear set. The pinion depth and backlash can never be correct. If you truly had a 7.5 gearset installed in an 8.8 housing there is no way on God's green earth that it has 189,000 miles on it.
