Changing 2WD to 4WD w/ donor truck
LilDirty91Xlt
British Columbia, Canada
So Im sure its been asked before, but Im lazy and half stupid when it comes to searching this place. :)
Question: Will the body of my 91 Scab, fit on an 88 Scab frame ?
Will my 3.0L bolt in place of 2.9L ?
Anything that I should know about that will definitely make the swap a nightmare ?
Your 91 body will bolt to the frame.
Your 3.0 should drop into the engine bay and sit on the mounts properly.
It will not bolt to the 4x4 transmission.
Hey, Scab...use the search function!!! Dangburnit....lol
Like said above, fairly doable just issues with the transmission, the chances of them both being the same manual transmission are slim, if auto then you could make it work as they would both be A4LD's...
Stray, lay off the people with low post counts... comments like that pushes a LOT of people away... I'm sure you were just prodding but still...
