computersoc
- Apr 16, 2013
2001 Ford Ranger XLT 2.5L manual transmission single cab 180k miles
It was time to change my radiator hoses as preventative maintenance. I bought new upper and lower hoses. Had a person I know change them for me. The old coolant was saved and dumped in through the radiator cap and some was put into the overflow reservoir.
Drove it 3 miles from the shop to a gas station and my temperature gauge on the dash was DEAD. Also heard a rattling when I would give it some gas. Felt like it was going all the way through the tailpipe.
Stopped at the gas station and as I hit the brake and was about to turn the truck off, the gauge went to its normal spot just shy of center. The overflow tank is almost filled to the top. When idling, the temp goes back down to the C. When I put the truck in neutral, and hold the gas pedal down to rev the engine, then the temp goes up a little, but still not to where it should be.
I drove it back home then another 1 mile and the temperature gauge then was where it should be, however it jumped around a little from a little above the C to shy of the middle, where it should be.
The overflow tank was still very full, so it obviously didn't suck it back into the engine.
Never at any time did the temperature gauge go to hot, or above where it normally should be.
1. Did I likely do any damage?
2. How do I fix this?
Thanks!
Thanks!
