bduke23
Well I decided for the first time to try changing brake shoes on my 93 ranger. Bought the spring tool, and went real slow taking my time. I did one side at a time, so I could copy the other side exactly. Bought a new hardware kit for it, changed the wheel cylinder on one side (it was leaking), and put anti seize everywhere the shoes contacted the backing plate. Bled the new cylinder, and took it out for a drive. Brakes were real soft at first, so I put the e brake on several time to adjust them, and they then felt much better. A couple blocks later, all of a sudden both the e brake light and abs light came on. Brakes still seemed to stop fine, however I could clearly hear something dragging inside the drum on the passenger side. I am 99% sure that I must have put something together wrong, but I copied each side exactly, and double and triple checked. That was late last night, I will have another look at it after work today. Anybody have any ideas what would set those lights off? And does anybody have or know where there is a good picture of all the springs and what not?
