(CCG Doubler) D20 + BW1354 -> Build thread
me too.
Not to mention the 3.15 crawler gears from Wild Horses you could put in that D20:icon_thumby:
mmm. i didnt remember that :drool:
I remember, somewhere...(i read that , maybe in tech section)...there are 3:15 gears available (dont remember the exact number) for the Dana 20...is that real? or 3:15 is the max? :icon_hornsup: or upper gears are available?
For the toyotas for example, they have 4.7 and 5.7....:mad:
372x513x248x315= 149:1....not bad!:shok:
I would like to know the total length of the shaft and was it turned, pressed and welded? or was it just welded and the weld turned down. Is the one end from a EB trans output shaft? Thanks!
Yeah, Wild Horses has 3.15 gears.They run $825.00. Thats as low a gear as i have found , but i just did a quick search.
You might find some lower ones though....
I've heard through the grapevine that DD will be offering a 1350/1354 to dana 300 doubler. Due out sometime late spring, early summer.
We have no data of the shaft length now (Vicho dont find the scheme). We fabbed a guide to center both shafts, and a 45º bevel to weld them. And yes, is the one end from a EB trans output shaft (D20).
