- Dec 3, 2007
- Manual
Please give me an explanation why. Just saying it doesn't mean anything. Maybe you don't really know. shady
Not to piss anyone off, but I see this EVERY TIME I come into the Exhaust forum, and I have yet to see ANYONE with a logical explanation of how backpressure helps power. I have to side with shadetree here. Or else someone needs to post a reputable reason, because it's just not logical. A two stroke uses quite a bit of flow technology to make power, but a four-stroke... not so much.
Engine builders run them because its.... FEDERAL LAW! Unless in closed-course racing.
They're on the Ranger you bought because 1.) the ECU needs them to operate properly (though its not hard to fool it either), 2.) it's federal law, and 3.) there's not alot of reason to lose them really, unless you're out to kill the environment ASAP. I took mine off because they absorb alot of heat, and heat = exhaust velocity, which = less lag time on a remote turbo setup like this. But they're really a moot point performance-wise when it comes to an N/A motor.
Really old cat converters were pretty inefficient - they absorbed a ton of heat and were quite restrictive for the system. Modern cats are far, far better. The "high performance, high flow" cats you see everywhere really aren't worth anything noticeable on newer cars over the stock converter either.
