Caster????
Tbmitchell
Solid Axle Swap
Chillicothe,ohio
okay so what the difference between caster and pinion angle... if there is one i mean when you adjust caster that is going to change ur pinion angle so is there a difference?
Caster is the angle of the steering knuckles (front to back tilt).
To set your pinion angle without screwing your caster angles up, you would have to rotate the knuckles back to where they are supposed to be when you have the pinion angle where you need it. To do this you would have to grind the welds off the inner C's and rotate them, then reweld them to the axle tube.
