BigWaffles
Hi all from a long time lurker. I just updated my ranger with a new 2010 model; I have the basic XL, Reg Cab 2.3L auto (manual not an option for me). I'm familiar with the rangers (this is my 5th), but this is my first automatic trans with a 4cyl. One thing I've noticed is on hills and with a load I have to run it pretty hard in the lower gears. I've been doing a lot of reading on the forums about the affects of heat on the automatic (kills it, mostly) and was wondering under what conditions that heat is generated. I know that most heat is generated when the torque converter is unlocked and/or the transmission is hunting between gears (constantly shifting). I was wondering about the following:
1. With the lock-up torque converter locked and the transmission in gear (not shifting), wouldn't it act like a manual (i.e. no slipping, minimal heat)?
2. When I’m going up a hill and hit the gas, the torque converter unlocks. If I hit the gas harder, it will downshift. I'm assuming its ok to take a short hill with the torque converter unlocked but bad for longer hills?
3. When hauling a small load (1000# or so) is it ok to run in OD on flat ground? With the converter locked and if it's not trying to downshift it should be ok right?
4. Is there any way to lock the transmission in 3rd gear? I know the OD switch will limit it to 4th and moving the selector to 2 will lock it into 2nd. Can this be done for 3rd or is it best just to turn OD off and let the trans select its own gear?
5. I plan on taking a full load with a small trailer (2000# total weight) down the Alcan in July. Aside from adding a cooler, what would you recommend as far as driving & shifting habits that will minimize the heat and wear on the transmission?
I know this is long and if it’s been covered please point me to the post; my reading covered this in general but nothing too specific.
I plan on using this truck to tow a small tent trailer and camping gear when I move to the states this summer and want to ensure that I'm treating the transmission well so it will last. Thanks for any help you can provide.
C.P.T.
C.P.T.
