use the "search" function... this has been covered so many times. over, and over again.
carb....no. you can take a 1989 f-150 5.0 computer and plug it ino your current 2.9 harness. then it is just a matter of lengthening 2 or 3 wires. and splicing in another 2 injector connectors and you are done. an efi 5.0.
i kid you not, it would be as much or more work to stick in a carbed motor. don't do it
yall can take all that efi and shove it i got my 302 HO in my ranger carbed and its much easier to deal with especially in the woods. not having to worry about mud and water messing up a sensor and my truck running like crap i got a sealed HEI and holley 650 4bbl weiand stealth alum intake no problems and there isnt a whole bunch of crap under my hood
efi offers better reliability, power, and fuel mileage. the only things that should still have carbs are dirt bikes and lawn equipment haha
They are wanting to make them fuel injected too.
Which is just great because people already have a cow at a $50 carb overhaul on their couple year old weedhacker...
What sensor is there on an EFI 302 of any year that would be affected by mud and water and cause your engine to run poorly?not having to worry about mud and water messing up a sensor and my truck running like crap
And that was after the government mandated the oil companies to mix at least 10% ethanol in all their gasolines.![]()
Kinda sorta not really.
Ethonals big problem with two strokes is that a little condensation seperates out the alchohol (which is heavier than gas) with the pickup at the bottom of the tank only sucks it up and this poor little two stroke is now trying to run on pure alchohol... with no oil mix.
We can still get straight 87 and premium, only 89 is E10.
Most carb problems are from storage issues. Darned if you do and darned if you don't, store wet and things gum up, dry and things dry out..
