Caps for the 2019 Ranger
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
GMRS Radio License
TRS 25th Anniversary
Aliquippa
PA - USA
Vehicle
Drive
2.3 EcoBoost
265/70R17
Anything that can go wrong, will go wrong. Plan for it as best you can.
Right now, LEER is the only manufacturer with product available. There are a couple others that say they have caps in the works, so I left the thread title generic for if and when that happens. Here is what I've come up with from the LEER web site and the brochure I picked up when I ordered my cap.
The current models offered are the fiberglass cab height 100XR, 100XL, 100R and the commercial aluminum DCC and DCC-MT3. Unfortunately, most of the models don’t have the Ranger pictured with a cap, just stock photos are various brands.
The details of what they come with as standard equipment, available options, and available packages, as listed in 2019, are as follows:
100XR
Hatch fully open
Screen Protectors
Interior view
Removable front slider window and cargo net
View of roof, rails, and Thule Areobars
Gas Prop Switch and 12V 3-Outlet Power Block
Rails removed and mount caps installed
Standard Equipment
  • Front Fixed Window
  • Frameless Curved Rear Door
  • Dark Tint Glass
  • Leer Flip-Lock Handle
  • Automotive Style Rotary Latches
  • 50/50 Sliding Windows with Screens
  • Interior LED Dome Light
  • Custom Fit Design
  • Automotive Paint
  • Insulated Roof
  • Recessed LED Third Brake Light
  • Fiberglass Base Rails
  • Skirted Rails (Varies by Model)
  • Installation Bulb Seal
  • J-Bolt Installation Clamps
  • Limited Lifetime Warranty
Optional Equipment
  • Interior Headliner (Black or charcoal grey)
  • Front Slider Window
  • Removable Front Picture Window*
  • Removable Front Slider Window*
  • Radius Side Windoors
  • Radius Side Windoor Sliders
  • Key less Remote
  • Additional Batter or 12V Dome Light
  • 12V Gas Prop Switch for 12V LED Dome Light
  • Interior Clothes Hanger (Single or Double)
  • Three-Outlet 12V Powerblock
  • Overhead Gear Net (Requires Roof Rack)
  • Overhead Storage Bin (1 or 2, requires headliner)
  • Thule Aeroblade Roof Rack System (Includes locks – choice of brushed or black finish)
  • Thule Tracker II Roof Rack System (Includes locks)
  • Thule Fairing (Fits Aeroblade and Tracker II)
  • Thule Tracks Only – Pair Installed
  • Thule Tracker II Load Stops 503 (Set of four)
  • Thule Areoblade Load Stops 502 (Set of four)
  • Thule Load Straps 15’ (Set of two)
  • Thule Quickdraw Ratchet System (Two – 13’ HD rope lines & four steel hooks)
  • Thule Big Mouth Bike Carrier
  • Thule Side Arm Bike Carrier
  • Thule Top Deck Kayak Carrier
  • Thule Portage Canoe Carrier
  • Thule Snow Pack Ski/Snowboard Carrier
  • Thule Snow Pack Telescoping Ski/Snowboard Carrier
  • Thule Outbound Cargo Bag (Rack mount cargo bag)
  • Thule Shuttle Paddle/Surf Board Carrier
  • Thule Canyon Cargo Basket
  • Screen Protectors
  • Cargo Hooks
  • LEER Locker**
Available Packages – Details Listed after Model Breakdowns
  • Americas Package
  • Acadia Package
  • Journeyman Package
100XL
Standard Equipment
  • Fixed Front Window
  • Dark Tint Glass
  • LEER Twist Handle Lock with Flip-up Weather Cover
  • Slide Windows with Twist-Out Vents and Screens
  • Custom Fit Design
  • Automotive Paint
  • Insulated Roof
  • Skirted Rails (Varies by model)
Optional Equipment
  • Interior Head Liner (Black or charcoal grey)
  • Keyless Remote
  • Additional Battery or 12V Dome Light
  • Interior Clothes Hanger (Single or double)
  • Overhead Gear Net (Requires roof rack)
  • Thule Tracker II Roof Rack System (includes locks)
  • Thule Aeroblade Load Stops 502 (Set of four)
  • Thule Board Shuttle Paddle/Surf Board Carrier
  • Screen Protectors
  • Cargo Hooks
  • LEER Locker**
  • Americas Package
  • Acadia Package
100R
Standard Equipment
  • Framed Door with Double T-Handle Locks
  • Dark Tint Glass
  • Custom Fit Design
  • Automotive Paint
  • Insulated Roof
Optional Equipment
  • Blank Sides (No Windows)
  • Thule Quickdraw Ratchet System (Two – 13’ rope lines and four steel hooks)
  • Screen Protectors
  • Cargo Hooks
  • LEER Locker**
  • Americas Package
  • Acadia Package
LEER Special Edition Packages
Americas Package
  • Thule Tracker II roof rack system
  • Interior headliner – choice of black or grey
  • LEER Locker
  • Dual 12V dome lights
  • Gas Prop Switch
Acadia Package
  • Removable picture or removable sliding window*
  • Gear net
  • Gas Prop Switch
Journeyman Package
  • Gear net
  • Gas Prop Switch
  • Thule Canyon cargo basket with stretch cargo net
LEER Special Edition Packages can be upgraded to include the Thule Aeroblade roof rack system.
* Removable picture and removable sliding windows are not attached with a hinge. They are locked into a channel when closed and slide out when opened.
** LEER Locker is a gear drawer mounted to the ceiling of the cap with slide rails.
Information was limited on the commercial caps when I visited my local dealer.
DCC
  • TIG Welded “Super Cage” Integrated Roof Construction
  • 035" Exterior Smooth Skin Aluminum Roof Metal
  • Stainless Steel Drop-T Handles and BOLT Locks with “One Key Technology”
  • Limited 5 year color and structure warranty
  • DCC fuse box
  • LED third brake light
  • Solid front wall
  • Black trim
  • Interior wire loomed and secured
  • Full length side doors with gas props
  • Solid half rear lift door with gas props and contoured door skirt
  • Heavy duty base rails for mounting
DCC-MT3
  • Offers modular toolboxes with adjustable shelf, divider, and attachment features
  • Wider, taller side access doors – up to 29% more entry space
  • Reinforced super cage infrastructure – 17% stronger than standard
  • LEER’s first all-aluminum truck cover with modular tool box capability
  • DCC fuse box
  • LED third brake light light
  • Solid front wall
  • Black trim
  • Solid lift half rear door with gas props and contoured door skirt
  • Heavy duty aluminum base rails for mounting
Saw these on a different website..
The roof on a 2019 Ranger.. especially on the SuperCrew, has a hump in it... you don't notice it to much until a flat cap is put on the truck. Looks weird IMO.
ARE Evolve
_______________________________________________
ARE Overland
_____________________________________________________________________________
ARE Z2
CENTURY ULTRA
Leer 100R
The LEER cap has a slight hump as well. I did notice the roof hump that you mention.
All beautiful caps! :) Undercover, produces a tonneau cover, that truly enhances the lines of the 2019 Ranger. Color match is flawless, the front hinge system ties into the bedside bulkhead, and is one of the best I've seen, it! It comes with wall hooks, and easily removes to hang on your garage wall, when you need the bed "height" to move that load. and the weight is around 80 lbs.
I have the Softtopper. I modified the Adrian Steel ladder rack and Decked the bed. The Softtopper will be removed or folded for the spring and summer Wisconsin weather
I saw a sport trac today with a cap, first ine of those Ive ever seen with one. Its crazy how much a cap costs now. in ‘92 I bought a new fiberglass leer for my ‘88 supercab, was $600, aluminum caps at that time were $300 new. last 2 caps Ive gotton for free, both longbed caps, one aluminum, one glass. Painted the fiberglass cap.
