willdav
I have a 2001 Mazda B3000. I just replaced the internal slave cylinder, clutch master cylinder, flywheel, clutch pressure plate....you know how it goes. Among all of that, the one thing I had a problem with. The bolt that holds the shift stick to the transmission is stripped. This bolt is some type of bolt that as you tighten it, the diameter of the bolt increases causing an increase in pressure. This results in minimal if any, play in the shift stick. Because it is stripped it has almost 4 inches or more of play. Does anyone know where to get this part? If you don't know what exactly I am talking about, here is a youtube link describing how to remove it, thus showing what it looks like:
