can't find spindles
Bigbbs
I have a 96 ranger 4.0 4x4 manual hubs the spindles are toast I've searched everywhere can't find them need a little help 27 spline
A '96 needs ABS spindles.
Though I have to wonder if you could get a non-ABS one to work with a little grinding to make a notch for the sensor... Not having actually done it though I can't say for sure.
Have you tried all the local junkyards? Spindles are not normally a wear item, so it should be possible to find good ones in a yard (all '95 & '96 and a portion of '97 Rangers were ABS).
Edit:
BG actually has the ABS ones too:
