Cant find any Warn Manual hubs for 1999 Ranger.
snowgear
I GAVE up on my 1999 Ford Ranger XLT, electric switch 4x4 and just bought a "Shiftster". NO More "GEM", vacuum hubs, modules, hidden fuses, and failures. I am taking the plunge to go ALL Manual.
I Was going to buy High end Warn manual locking hubs, but the Warn website says they DO NOT make any for 1999-2001 Ford Ranger.. I do NOT want to buy a Dana front axle, or do any mods,..
Ebay motors offers a few sellers offering WARN hubs for INTERNATIONAL ford rangers only, NOT U.S. market.
Many sellers offer Mile Marker, AVM, or Rugged Ridge for 1999-2001 Ford Rangers. I want the BEST made, price is NOT a concern.
If I cannot by WARN,, what is the best manual locking hub of the three?
I do NOT go off road ever,, I just live in heavy snow country, and will gladly crawl underneath to engage the SHIFSTER into 4 wheel HIGH, and then lock the hubs.. I will be in 4x4 only for Mountain passes and snow.
Any help would be great.. I bought the SHIFSTER from Advanced Adapters,, they have them IN STOCK. Thanks,,
Tim , Washington State.
Actually the "best" is the simplest thing and though it costs you 0.5-0.75mpg
you can do what I did to a friend's '99 Supercab...
Swap out the steering knuckles, hubs and outer CVs off of a '95 up Ford Explorer...
or later Ranger made AFTER ford gave up on those stupid pulse vacuum hubs.
If you can manage it the '04-up have larger and thus presumably better brakes, but use different caliper, caliper brackets, rotors and brake pads, but I have not personally experimented with what else needs to be changed to allow the retrofit, ask me later this summer, I have an '01 frame set that I'll be upgrading with the latest brakes I can aquire.
AD
I had a set of the RR hubs on my 99 when I bought it. They were blown up. Pieces of metal everywhere. And a shifster on the original T-case. I've since swapped that one out for a manual BW 1350.
I bought the mile markers and haven't had a single issue. Haven't really had the truck in anything bad but I have gone up a couple rutted out roads while deer hunting. She never spun a tire or blew a hub.
I think the RR and MM are the same just rebadged. I could be wrong though.
I've heard that but there are differences. The gripper teeth that hold it on are different I know, but as far as internals I didn't compare them.
Maybe a stupid question but how do you switch from 4HI to 4LO with the manual hubs?
That's all controlled by the transfer case. Just stop the truck, put the transmission in neutral or push in the clutch, shift transfer case to 4 low, shift back into 1st gear or drive and take off.
Yep
