ezekiel.8g
- Oct 14, 2009
- Automatic
i got a 97 2.3l with a misfire on#3, ive checked the packs , injectors, replaced plugs and wires, compression test was good( all were between 140psi-150psi).a buddy told me it might be a burned valve and to do a leakdown test, but compression is good and im not smoking from the tail. wierd thing is sometimes it runs fine,no misfire, i got the misfire p0303 after i checked and replaced air filter,and worn hose that sits on tb that was pluged;lead nowhere,along with the p0303 i somtimes get p1131 but not always.thats where im at right now im hoping someone can give me some help, im stuck.
