Can't disengage 4WD Low.
engine
Ashe Co NC
Total Drop
245 75 R16
2002 Ranger stuck in 4WD Low. What to do?
Normal way to do it is put it in neutral and press the brake then switch it to 4 hi. The truck has to be stopped and in neutral to engage/disengage 4lo. Also disconnect the battery for a minute or so and hook it back up. It resets the module. That worked many times for me, If that does not work you can remove the shift motor and manually put it back in 2hi. It is marked on the casing when you take the shift motor off.
