- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
I wouldn't go any newer than '94, I don't know how the older tech 5.0 would play with the newer electronic dash in the 95+ Ranger. I don't know how well it would work in some of the older Rangers (carburation was an option up until '88 with some engines)
Didn't think about the speedo, it went electronic in 95 didn't it, and the gauges take singals from the ECU rather than senders. As I mentioned those EFI systems can be made to work on their own, once that is done the engine and EFI system doesn't care what vehicle it's in. As long as it's got power, ground, ignition, and fuel it could be run on a stand. The issue is getting the gauges in the vehicle to work once the engine is in.
A 302 is not a 302. Different intakes, pistons, camshafts, lifter/cam type, oil pan/pickups, cylinder heads and FEADs are all fairly important differences that complicates mixing and matching stuff. A '96 Explorer 5.0 is very different in its swapping and power potential than a '96 F-150 5.0.
Not to you or me, but does this guy sound like he can understand that? He doesn't seem to be too interessted in listening either, we've already mentioned the Explorer, the intake, etecera and he just keeps coming back with the same can it be swapped question. He doesn't seem to be too interested in trying, he dead set on just bolting that F-150 engine and transmission into a Ranger. If that's the way he's going to be he needs to forget about a Ranger V8 swap and find a 95 F-150 or Bronco that needs a drivetrain.
