2.5L ('98-'01) can you help me what is this hose?
noisyboyy
Firefighter
california
this hose is hanging over my ac unit . it looks like a vacuum hose . don’t know where it goes anyone know ? thank you in advance
Is part of it a Grey hard plastic hose?
If so it goes to the Heater hose By-pass valve, has 4 heater hoses connected to it, yes a vacuum hose
End often broke off so rubber hose was used as a "patch"
Other end runs thru firewall and goes into the cab under the glove box next to passenger side kick panel
It changes to a White hose in the cab
There will be a black hose running next to it, this is a main vacuum hose from vacuum reservoir in the engine bay, it runs the cab vents, defrost, panel, floor
The white/grey hose only has vacuum in OFF and MAX AC settings, so not "a vacuum leak" as far as engine or cab vent system is concerned
Looks like HeaterByPassValve+Actuator where this VacHose connects is near bottom of your 2nd pic above.
awesome thank you both . I will look again but i didn’t see any place to connect it . there were no nipples or places to connect hose . I will look tonight when i get home . thank you both for the quick response
RonD , Dillard000,
thank you both so much . I found the where the connection for the hose went . the valve nipple was hidden by a hose so couldn’t see the nipple . the info and pictures got me right to the fix . thank you both for the info and pictures . I really apprecaite it .
Ty
