I have a 94 Ranger but I have already swapped the front brakes to the 95 dual piston calipers & outer spindles. I know that the Mustang has the same bolt pattern but they have a separate hub & slip on Rotor. If this could be done it would be cheaper in the future as the Stang rotor is cheaper then the rotor hub assembly used on the Ranger.
Not sure about inner & outer mustang bearings working on the Ranger spindle though.
Any input would be great
